[solved] creating a see through material with pattern
I need to create a metal pattern with a PNG image.
What map should go where?
Thanks a lot
Keren
Invert attached map and plug it into opacity slot.
Is that a wall divider? What exactly you are trying to make, please share more information.
Thank you all, It came to me after a while, of course, to put the negative in the opacity slot. I’m just a little rusty…
