I took a brief look at the logs, but I am afraid it’s a case for Deadline support.
Looks like there are multiple errors there, about “log4cplus” and some missing plugins.
What exactly do you mean by replacing your CPU? Did you just install a different CPU in the same PC, or built a completely different PC?
do you have any clue why progress bar is not moving in deadline monitor? on slave pc I can see the progress but on monitor no
also I am having issues - when finished the job right before render output would save, slave job crashes. Same happens when I try to save image during rendering
Can you please contact us at support@corona-renderer.com and describe your exact workflow better? A step-by-step instruction would be best, or a video recording showing what you are doing, and what is happening. We will then contact Deadline devs and will see what can be done about it.
yes it should be that. Regarding the secong issue - I think it might have been caused by wrong setup of output path, which was set to local and not network
