[solved] DR and FFP, not working good
I have a problem with Forest pack and my render farm …
When I render on my 3nodes with the DR, the textures of the plants used with Forest Pack Pro are transparent … in fact it happens from the moment when two nodes slaves make passes.
My other textures of the scenes are well rendered. The paths are opperial.
It is only with the plants used in FFP that there is a problem.
Is there a manipulation to be carried out?
Should install FFP on all my computers? Should it install all the textures also?
Has anyone ever had this problem?
thank you.
Yes, of course :smiley: They will not render any ForestObject if you don´t install the plugin.
Basically install everything you need on your workstation to render a scene on every slave as well.
Good Luck
Thank you Frood!!
problem sold!!
installing plug in on my two other nodes made it work..
:smiley:
