[solved] DR nodes - various RAM usage
my render nodes dont get the same amount of data when rendering, but they are all the same…
Is it normal ? Does it influence the render time ?
Thanks ! :smiley:
looks like you are having the same issue as me, maybe. The ones with very little RAM being used arent doing anything toward renders by the looks of it.
I get this problem where some nodes just hang with “waiting to start” and sit around 5GB ram. while other nodes just pick the render up and go.
edit - currently have a ticket with corona support to try n see why this is happening.
In fact I found the problem this morning, some PCI drivers wasnt nicely installed and they blocked smthg…
I just changed all my MB so I had to recheck all drivers.
After installing the PCI driver, everything run smoothly on every nodes.
