[solved] Dr Server No updates, no passes
Hello everyone, there was a problem with Dr Server. The problem is with this particular scene, on the slave the rendering is going on and there are no errors, but on the main computer there are no changes from the slave
2021-11-23 08:41:53 Parsing scene took 27.370000839233398 seconds
2021-11-23 08:41:53 Calculating displacement
2021-11-23 08:41:55 Computing displacement took 1.7940000295639038 seconds
2021-11-23 08:41:55 Preparing geometry
2021-11-23 08:41:57 Embree: memory usage: 1 GB. Total embree build time is 1797ms, top level commit took: 1099ms. There are 131 embree geometry groups, 15 instances, triangle objects: non-animated=153/animated=0, hair objects: non-animated=0/animated=0, custom objects: non-animated=0/animated=0, particle objects: non-animated=0/animated=0
2021-11-23 08:41:57 Preparing geometry took 1.9830000400543213 seconds
2021-11-23 08:41:57 Preparing lights
2021-11-23 08:41:57 Preparing lights took 0.095000006258487701 seconds
2021-11-23 08:41:57 Computing sec. GI
2021-11-23 08:42:00 Estimated time left: 0:00:12
2021-11-23 08:42:02 System is running low on RAM. You may experience excessive parsing times and/or crashes. You will probably have to simplify the scene.
17 GB of virtualized* RAM used by Corona + 3ds Max
51.1 GB of virtualized* RAM used by all running applications
31.9 GB of physical RAM installed on system
53 GB of virtualized* RAM provided by OS
  • virtualized RAM means physical RAM + swap file on HDD/SSD
Corona RAM usage breakdown:
5.9 GB used by render elements
2.4 GB used by geometry
3.7 GB used by textures (CoronaBitmap only)
2021-11-23 08:42:03 Computing secondary GI took 5.7080001831054688 seconds
2021-11-23 08:42:03 Rendering initial pass
2021-11-23 08:42:26 Internal error. Please report it at https://corona-renderer.com/link/2001:
bad allocation
2021-11-23 08:43:14 Rendering pass 2
2021-11-23 08:44:20 Rendering pass 3
2021-11-23 08:45:24 Rendering pass 4
2021-11-23 08:46:28 Rendering pass 5
2021-11-23 08:47:32 Rendering pass 6
2021-11-23 08:48:35 Rendering pass 7
2021-11-23 08:49:40 Rendering pass 8
2021-11-23 08:50:46 Rendering pass 9
2021-11-23 08:51:50 Rendering pass 10
2021-11-23 08:52:54 Rendering pass 11
2021-11-23 08:53:57 Rendering pass 12
2021-11-23 08:55:01 Rendering pass 13
2021-11-23 08:56:08 Rendering pass 14
2021-11-23 08:57:18 Rendering pass 15
2021-11-23 08:58:32 Rendering pass 16
2021-11-23 08:59:46 Rendering pass 17
2021-11-23 09:01:07 Rendering pass 18
2021-11-23 09:02:34 Rendering pass 19
2021-11-23 09:04:00 Rendering pass 20
2021-11-23 09:05:28 Rendering pass 21
2021-11-23 09:06:54 Rendering pass 22
2021-11-23 09:08:20 Rendering pass 23
2021-11-23 09:09:51 Rendering pass 24
2021-11-23 09:11:24 Rendering pass 25
2021-11-23 09:12:52 Rendering pass 26
2021-11-23 09:14:20 Rendering pass 27
2021-11-23 09:15:47 Rendering pass 28
2021-11-23 09:17:15 Rendering pass 29
2021-11-23 09:18:43 Rendering pass 30
2021-11-23 09:20:11 Rendering pass 31
2021-11-23 09:21:38 Rendering pass 32
2021-11-23 09:23:08 Rendering pass 33
2021-11-23 09:24:36 Rendering pass 34
2021-11-23 09:26:05 Rendering pass 35
2021-11-23 09:27:33 Rendering pass 36
2021-11-23 09:28:41 Rendering pass 37
2021-11-23 09:29:52 Rendering pass 38
2021-11-23 09:31:03 Rendering pass 39
2021-11-23 09:32:16 Rendering pass 40
2021-11-23 09:33:31 Rendering pass 41
2021-11-23 09:34:54 Rendering pass 42
2021-11-23 09:36:20 Rendering pass 43
2021-11-23 09:37:44 Rendering pass 44
2021-11-23 09:39:11 Rendering pass 45
2021-11-23 09:40:40 Rendering pass 46
2021-11-23 09:42:09 Rendering pass 47
2021-11-23 09:43:38 Rendering pass 48
2021-11-23 09:45:03 Rendering pass 49
2021-11-23 09:46:28 Rendering pass 50
2021-11-23 09:47:54 Rendering pass 51
2021-11-23 09:49:19 Rendering pass 52
2021-11-23 09:50:45 Rendering pass 53
2021-11-23 09:52:10 Rendering pass 54
2021-11-23 09:53:36 Rendering pass 55
2021-11-23 09:55:03 Rendering pass 56
2021-11-23 09:56:29 Rendering pass 57
2021-11-23 09:57:57 Rendering pass 58
2021-11-23 09:59:24 Rendering pass 59
Hi, I replied to your submitted ticket, we can continue there and post the solution/problem later here.
(Ticket 12957)
Fixed by lowering “max pixels to transfer” in the DR rollout.
