[SOLVED] Error loading plug-in DLL [3ds Max Design 2014]
I have been using Corona in 3ds Max Design 2014 on my work and everything works fine. However, something went wrong on my personal pc because I keep getting the following error messages:
Error Loading Plug-in DLL
DLL <C:\Program Files\Autodesk\3ds Max 2014\plugins\CoronaUtils2013.dlt> failed to initialize
Error code - 1073741795 - (null)
and
DLL <C:\Program Files\Autodesk\3ds Max 2014\plugins\Corona2013.dlt> failed to initialize
I have all the 4 dll from Corona, my 3ds max installation is new (and I reinstalled again after this problem) and I have 2005, 2008, 2010 and 2012 MSVC redistributables .
Any solution for this problem?
Many thanks,
Check’em Chaos Corona - Global Site
Thank you so much Keymaster. I searched the entire forum looking for something. In fact my windows installation is brand new.
I will keep you updated.
It’s working, but you need to install the service pack first.
Thanks for the help
I have the same problem and link above dont work. Can you help me please?
Hi, here’s updated link: https://coronarenderer.freshdesk.com/support/solutions/articles/5000501938
Thanks!
is not working. can you help with installing corona
coronautils2014
the message DLL failed to initialize. Error code 1073741795
Hi, next time try here:
http://www.corona-renderer.com/help
This specific problem is described here:
And Corona installation here:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501681
