[Solved] Help: Open tone mapping settings editor from script
Does anybody know if it is possible to open a camera’s tone mapping settings editor from maxscript or a macro?
This button:
Thanks!
Not conveniently, but you can get a reference to the UI and let windows press the button. Example macro:
macroScript OpenCCamToneMapping
	category:"# Scripts"
	toolTip:"Opens tone mapping edit window of current Corona camera."
	icon: #("Systems",2)
on isEnabled do (
	return ((classof (viewport.getCamera())==CoronaCam))
on execute do (
	max modify mode
	select (viewport.getCamera())
	TMButton=windows.getChildHWND (windows.getChildHWND #max ((viewport.getCamera()).name))[7] "Edit..."
	windows.sendMessage TMButton[1] 0x201 0 0 -- LMB down
	windows.sendMessage TMButton[1] 0x202 0 0 -- LMB up
Coding like this it is crap, but it works.
Good Luck
Thank you so much, that has worked great!
Had to change it a little to get it to work with my python script. If anyone’s curious:
from pymxs import runtime as rt
parent = rt.windows.getChildHWND(rt.name("max"), (rt.viewport.getCamera().name))
tm_btn = rt.windows.getChildHWND(parent[7], "Edit...")
Thanks again, I really appreciate it!
