Hello guys, I’m having a few problems with Corona (9 hf2, 9 hf3, 10 rc1).
The first problem I notice is that loading the interactive render takes a lot more time than it used to, it could even be around 2 minutos. But something weird about it is that when it finally shows the rendering process, the rendering time could be over 45 or 50 seconds. Even sometimes the Stats show Scene parsing 0:00:00, Geometry: 0:00:00, UHD cache precomp: 0:00:00 but about a minute of rendering time.
And the second problem is that when I isolate some geometry, start an interactive render, stop the render and try to exit isolate mode, it takes around 30-40 seconds to show all the geometry. If I isolate and exit isolate without an interactive render in the middle it has no problem.
I’m attaching a video showing the two inconvenients.
I’m using 3ds Max 2024.1, Corona versions as mentioned before, Forest pack 8.2.2, Railclone 6.0.7, Anima 5.1.1
Win 11.
My PC setup is Threadripper 3990x, RAM 128gb, RTX 4090.
Project is located in local M.2 and assets are located in an SSD network drive
