hello,
can you tell me the way to assign a lightselect render element to a specific light material?
In my lightmix tab, light materials are always on “unassigned”…
thx for your answer!
Should happen already - if your light is a CoronaLightMtl, the automatic setup will work respecting the group that the object is part of (see https://youtu.be/JRNxxzgUhSw?t=4m59s ).
For adding manually you should be able to click on either the top level of a group, or on the specific object, using the + button in the LightSelect render element. Note that it is done by object, rather than by material, that is, you can’t have one LightSelect that handles all objects with that particular material applied (well, you can, but you add the objects to that LightSelect rather than add the material itself).
Let me know if that helps!
Thx tom for the reply! it works.
Thx a lot.
NP, and good to hear you are up and running!
