[solved] Lighting - on transparent background
Hello Everyone!
I need to render ONLY light on a transparent background…
I have attempted to use the corona shadowcatcher but I’m only able to get the light on the background using the option “alpha mode: always solid”, when using “alpha mode: for compositing” the light does not show up on the shadowcatcher…
If anyone can help me render light on transparent background it would help out a ton!
Below I have attached what it looks like when the shadowcatcher is set to always solid and for compositing.
test27.exr (375 KB)
test28.exr (885 KB)
Does your light object have the option “shadowcatcher illuminator” enabled?
Solved it by combining all the light selects in the scene.
