[solved] Portal problem
Hi guys !
Here is a scene with small openings, i applied portal material to planes covering the windows perfectly ( like shown in corona guide ) but i always get a dark room, plans don’t allow light to come in
is there a problem guys !
Let’s start from eliminating dumbest variants. Did you assigned portal material to “portal” planes? If so, maybe you’re rendering with material override and forgot to exclude portals from overrides?
loool yes you are right, i think i need a coffee cup to wake up hehehe , thanks romullus !!
