[solved] Problem rendering animations with Corona 11
Hi all,
I did not experience this before but with Corona 11 the animation is not always showing correct in the rendered frame. Is there anything I should be aware of? I did set it to the animation preset in the render setting but this does not change it. It’s just a simple rotation animation so it seems a bit overdone to have to bake this down.
Thanks,
Joost
Nevermind, turned out the frame rate in the Render Settings did not match the document. :see_no_evil_monkey:
Happens to all of us :smiley:
