[solved] Proxy texture issue
When I convert a model with 5 different material IDs into Corona proxy it renders fine but if I copy the proxy(tried both copy and instance) 10 times all of them lose its texture. However, some other models like a whole tree don’t have any texture problems.
I’m just trying to save scene file size with proxy for high poly. Any solution? I found a topic but it was about C4D.
NVM, it was bad model causing render issue. I remodeled it and it renders fine.
