I searched the help section and didn’t find a solution for this…
Is there a way to produce an element similar to Raw Lighting in Vray (in the attached image) ?
maybe an override element with exclude option ?if possible…
is that possible even if it was a cheat like rendering 2 elements and maybe subtracting one from the other !
PS: the image is not mine I found it in google
I believe what you need is CShading_RawComponent element.
yep I think you are right thank you
