[SOLVED] Render Elements crash 3DSMAX 2015
I was unable to use the Corona with Render Elements. Whenever set to render any element 3DSMax closes . What to do?
Does windows has all updates installed? Does max has all service packs installed? What version of Corona you’re using? Does this happens with all scenes, even freshly created or just with particular scene?
I have:
Windows 10 with all updates.
Corona 1.2.1
Autodesk 3ds Max 2015 Service Pack 3
This happen anyone scene that i build.
Is your output path of render elements set up correctly?
When the error is visible, please follow these steps and send us the minidump file (to support@corona-renderer.com):
“2. Reporting Error Messages or freezes”
https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
Follow dump files and corona version. I do download…but i cant use still and my license is expiring… :confused:
corona-crash-max.zip (796 KB)
I send also files to Corona Uploader
This looks like internal error in 3dsmax. It looks like Corona did not contribute to the crash. It could be caused by some other applications you have installed that modify all windows (such as teamviewer, antivirus software, …). Does this happen only with Corona, or also other renderers? Have you tried different 3dsmax version? Or a different computer?
I´ll try reinstall my 3dsmax 2015 again…I hope that it is all right
Thanks so much for help!
After much research , I found the solution. Corona is not the problem.
Wacom driver is conflicting with Render Elements in 3DS Max 2014/2015. Even updating the driver the problem persists.
Render Elements causes a crash when I try to add a pass (Autodesk Forum)
More infos in: http://forums.autodesk.com/t5/3ds-max-3ds-max-design-general/render-elements-causes-a-crash-when-i-try-to-add-a-pass/td-p/5652367
Very grateful for the support.
Regards!
SOLVED
