Im not sure if its still an unstable feature but my ‘resume from file’ doesnt actually resume the render. It dumped out a 300MB exr using the save VFB button and then tried to resume the render after about an hour. When i choose the file to resume from it loads into the buffer and then the render dialog says ‘saving + closing’ and then the render stops.
Any ideas?
Jack
Which version of Corona are you using?
It should just work. Didn’t you change any render settings? (resolution, internal resolution,…?)
Are you getting any error messages or warnings?
1.3 installed yesterday. I did adjust the resolution but i changed it back before trying to resume. Didnt change any other render settings. Is that a problem?
Are you sure you are using the same resolution as in the saved EXR? You could just open it in PS and check the resolution.
Everything needs to be the same as when the EXR was saved.
Ah, just checked i had the image aspect wrong. My Bad.
Thanks ![]()
