[Solved] "Scene bounding box is too large" in interactive mode
For the past few days, whenever I try to scale or rotate more than one object while Corona Interactive Rendering is running, the selected objects suddenly jump extremely far from the scene’s origin. At the same time, I get the following message:
Scene bounding box is too large, some shading artifacts may occur.
This behavior only happens during interactive mode — everything behaves normally when interactive rendering is off.
I’ve tested this on clean, empty scenes with just a few primitives (boxes, spheres, etc.), and the issue still occurs consistently.
I’m using:
3ds Max 2025
Corona 12, Update 2
Is this a known issue? Could it be related to preferences, system units, or something else?
Thanks in advance for any help or insights!
This issue has been fixed in Update 2 Hotfix 1 See changelog and download link: https://forum.corona-renderer.com/ Chaos Corona 12, update 2 for 3ds Max (Hotfix 1) released
Thanks a lot!
I hadn’t seen this hotfix was released — just installed it and everything works perfectly now.
Appreciate the quick help!
