[solved] Shadow Catcher - background see throgh objects
Hi
use a picture as background of my render, I used perspective match to fit object in scene and integrate with background, I know I should use shadow catcher for parts I want to take shadows but the problem is : put a picture as screen in enviroment that see in render , and object in scene, in this step when I render I can see background through my objects??? I do not want that what should I do? I attached a picture
thank youuu
Do not put background picture into enviroment, use enviroment overrides>direct override in render setup instead. Enviroment is used as ambient light in Corona and it always should be used with spherical mapping and not the sceen mapping, otherwise it will produce wrong result as in your case.
You can read more here: https://coronarenderer.freshdesk.com/support/solutions/articles/5000501978-how-to-set-up-hdri-environment-
Thank Youuuuuuuuu :folded_hands::folded_hands::folded_hands::folded_hands::blush::blush::blush::blush:
