[solved] White Dots in corners
Hello Guys,
I m a new user in corona , but its really fantastic way its rend so beautifully
But i have getting small problem when i go fro panorama i mean spherical render
i get small dot on floor and roof
and i also try to reduce the noise
Noise visible in direct light (CEssential_direct pass)
Using(Corona version: 1.1.1)
Please guy help me about it
are u using a round corners shader in these materials?
Greetz
Lucutus
No i didn’t its default as it is
Maybe this can help you.
https://coronarenderer.freshdesk.com/support/solutions/articles/5000516209-i-can-see-noise-in-the-corners-of-my-scene-
greetz
Lucutus
Give some thickness to your walls (by applying shell modifier, for example) and those small dots should dissapear. As for noise, if it’s mainly in direct pass, then you’d most likely want to increase LSM to 4-6 and render till noise will converge to acceptable level.
ninja’d by Lucutus :]
thanks
Lucutus
its fixed
thanks alot
you are welcome :wink:
Greetz
Lucutus
