Hello
With interactive mode rendering in 3dmax viewport in some cases i need to render in VFB buffer with some bigger resolution/
In this mode interactive viewport in max is Lock (it’s very very good), but to stopping render in VFB i get VFB is clear, { because of the inclusion interactive mode in max viewport}
it is impeding work since I do not see the result of rendering in VFB/
It is impossible making something with this in the future ?
Yes, it has to be fixed.
You can bring back your last rendering by going to Rendering > Rendered Frame Window - this will show you standard 3ds Max VFB with your most recent rendering.
Another idea is to use floating interactive rendering window instead of docked one (render setup > scene > start interactive). This will show interactive VFB. To switch to regular rendering, just click on “stop”, then “render” again. To run interactive rendering again, click and hold on “render” button, and pick “start IR”.
