some damn fast render time's
hi guy’s
just doing some test renders today and started playing with the QMC and started to produce some very fast test renders… have a go yourselve’s.
here are the settings, see what you think
Please bear in mind that these settings are purelly for test renders
can you post some images of what those settings produce and most important , render times??..
those settings look really odd/different from everything I’ve used/seen before…but hey, if they get faster tests I’ll be the first to adopt them :smile:
show us more…
thanks natty,
paul.
natty,
that stuff is GREAT!!! :smile: :smile: I shouln’t have doubt ya :smile:
with my usual test settings
-4/-1 min/max for Imap
0.5 clr tresh
0.4 normal thresh
40 Hem subdv
20 interp.
(default settings for QMC)
Max tree deepth 63
face/level coef 0.5
AA > fix rate = 1
color mapping > HSV esponential darker = 1 brighter = 1
it was taking a little over 17 mins calc Imap and rendering from scratch.
with your settings the whole thing came down to about 11 mins.!!! :shock:
the only problem I see is that even though it calculates the Imap VERY fast it seems that the rendering itself takes almost longer or as long as with my above settings…so I need to work on that…but it’s still a HUGE improvement plus the quality looks the same as w/ my old settings above, good for a test rendering… :slight_smile:
we should investgate this further…
thanks for sharing!
I’ll keep playing w/ it…
paul.
cut the QMC min sample in half to 50… and the direct comp down to 2 and 2 …interp to 150… watch it rock :shock:
…and rocking it does, my man :shock: :shock:
In the rendering above I had 20 lights and your settings (first post) and it took 11mins…w/ AA set to fix rate = 1 …and full refelctions for glass..
now I added 3 times as many lights (60) and added your new settings (above) and its still only increased of 3 minutes…
damn nice, Natty!!! :smile: :smile: :smile:
w/ my original settings (see above) it probably would taken around 35 mins…with yours took only 14 mins…
thanks much :!:
paul.
Been playing with it for a couple of hours now and here are the results..
Further Optimized settings from last post
Scene File
http://www.render-time.com/vray/speed.rar
Wow Natty - great time savings tip for testing!! Thanks a stack :!:
Dean
hello natty,
i guess something is weird over here, because i used to played with this settings some times ago and in my tests i’ve need to decrease min samples and not increase it. For exemple, i take a try now and render a image with 100 at min samples, just like you. My time render was 2:34, than i put my old values, 10 to min samples and i got a render time of 2:10. Take a try in your images and tell me if this is right. The only difference betwen us is that my image is a external image with two buildings and yours is a interior image, perhaps this must the diference.
see you bud
silver
Hey natty
I think your link might be down mate :slight_smile:
link will be back up tonight .. :wink:
ok, working now
mhm… more samples = more calculation = slower.
whats wrong here?
whats wrong here?
It is the QMC values, it is set to cut off most of the rays.
wow
i opened you file and rendered it…got 32.5
im using dual Xeon 3.06 with 1mb cache each. Thanks nat…
Thanks Natty, just opened and rendered on my dual xeon 2.8 and got 36.0s :slight_smile:
-dave
It works
i tried something way out of norm…i have this model which has 3.2 million faces and tried rendering with the settings nat came out with…and the result is a shocking improvement…used to take 6 hours plus…now just 2 plus…way to go nat.
niiiiiiiiiiiiiiice 8)
-dave
hey guys!
have u try these setting render in motion animation, i notice that ‘noise’ effect will come out all over scene. any idea? :roll:
hi all
the settings are great! BUT with glossy reflections the samples of 150 are too much for test renderings…! I’ve tested this right know.
any ideas to reduce rendertime, but keep the quality?
best regards
themaxxer
i only use these setting purelly for test render through out the day … just to get the lighting right … not for production renders :wink:
