Some Elements Not Showing in Render After Adding a Phase in Revit
Hi there,
We use Revit 2019 and Enscape 2.5.2.37.
Until a week ago we would use Enscape and everything was just fine. Last week we needed to create a new phase to our project. Since this new phase was created, some elements do not appear in enscape renders. the phase filter is set correctly and all the elements appear in the Revit view Enscape uses to render, however they do not appear in Enscape. I can roughly say that all elements which have been modeled before the new phase was created appear in Enscape, the elements modeled after the new phase has created do not appear, no matter what phase they are on. All items in the model have as their phase demolished: none and I tried to switch missing elements between different phases but that didn’t help: they do not appear in the render no matter what phase I put them on.
could anyone please advise?
Thanks.
It’s not likely Enscape. Something has been edited in the Revit Phase or Phase Filter settings that isn’t intended. Try this:
  1. Close Enscape
  2. Delete your default Revit 3D View and then create a new default 3D View.
  3. Set Phase and Phase Filter to show the desired condition
  4. Make the Default 3D View the Active Document in the Enscape menu
  5. Start Enscape
Does the same condition display in Enscape and Revit?
