I don’t see the ceiling layer in enscape. Please help.
any advise?
Make sure that the surface is not tagged as “Water”
(If the name of the texture contains ~river~ or ~ocean~ or ~water~ then it will automatically tag it as a “water” material and make it translucent in the Enscape window)
@susan unsil lee Please let us know if your issue persists, you can also forward us your project on our support email - .
You can use a file sharing service like https://wetransfer.com/ to share the file.
Thank you. I found the ceiling color paint name was ‘Indian river’, so I changed the name without 'river’and the problem is solved. Thank you so much. ![]()
