Some little annoyances
Both of those do the same. I guess I understand because of one being eevee and the other cycles. But maybe one could be vray gpu and the other one vray cpu.
But one annoying thing is, in SOLID view we cannot see the textures. I always have to be in render mode. This needs to change. Also denoising with cycles is still a much faster and smoother experience then vray. Vray has always had slow denoising.
Screenshot 2026-10-09 200046
Yes, in most cases, Cycles denoises faster than V-Ray. However, in my experience, V-Ray performs better under heavy VRAM usage and delivers better rendering quality than Cycles. What I’d like to see improved is the V-Ray experience in Blender’s viewport. Currently, the VFB is noticeably smoother than the viewport, and I hope the viewport experience can get closer to what Cycles offers.
By the way, I think they should improve V-Ray GPU’s speed and user experience, as Octane has done, by adding features like real-time neural IPR rendering. These days, it seems that only a small minority still use V-Ray CPU—they could just use Corona instead.
F1 fan here, seeing your name made me smile.
Long live Ayrton Senna! :slight_smile:
  • Love from a Max Verstappen’s fan
Your comment made my day!
I Love max!
sending you much love!
Not sure if thats what you meant but there is an option to display textures in solid mode. Major downside is that you have to manually select the bitmap node to show up in the viewport(which is a blender limitation from what I found on google)
Pretty sure claude etc would be able to write you an addon that would make that automated by an N panel button or something like that
