Some minor stuff I've noticed
I’ve found some tiny bugs (?) that don’t much affect workflow but are pretty annoying. Windows7, max2012
When I set Corona as active renderer sometimes the default settings are ok but sometimes some of the values are different - for example “Custom mat. ed” is not checked, max sample intensity is set to 0 instead of 10, in HD cache Precomp step is set to 1 instead of default 10. Anyone else noticed same stuff happening?
Also, in material editor when I am editting a CoronaMtl material pressing TAB key switches cursor to crazy locations instead of next value. Is this intentional?
+Exit color sets itself to blue (0,0,255)
hm, thats production defaults not activating. You are getting my debugging defaults instead. I’ll have to look into it.
I know about the second problem, its just pain to set up correctly, so I was doing new algorithms instead until now :wink:
I think I know when this is happening: when you use Corona in one scene and then reset scene so that Corona loads up as active rendere automatically for an empty scene.
If you change default scanline to Corona it’s ok.
  1. in TODO list before the next alpha
  2. fixed
cool, thanks
1 fixed
