some mtl. test
im still making objects that will be placed in my scene.
this lampshade is making with vray2sidemtl.
i spent a lot of time to make lampshade, because of manual.
manual dose not explain about the details of 2sidemtl.
good luck.
Re: some mtl. test
Howard
Really excellent work. I look forward to the scene with these objects in. This is a labour of love!
Regards
David
Re: some mtl. test
Elegantly made! Keep it up! :slight_smile:
Re: some mtl. test
i agree with you there are some other things there the manual doesnot explain. so good test hong.. i notice you use depth of field on the first image.
Re: some mtl. test
Thanks to all.
its very difficult to handle DOF of VfSU.
i cant get the good results that i designed in my mind.
i think VfSU wont give proper hyperfocal distance.
and theres some kind of cunfusions using word’s definition of F-STOP, F-NUMBER.
so, i decide to understand the words’ definition of VfSU has a little different meanings.
even though, VfSU is very nice.
ps. the lamp above has two Emissive bulbs, can you notice too?
Re: some mtl. test
hey
how can i create as realistic glass as photo shows?
Re: some mtl. test
as you know, we can make many kinds of glass.
wine glass is one of them.
heres screen shot,
be sure to make your wine itself little larger than glass.
and heres material.
the reflection value of reflection tab is 243.
help your self.
Re: some mtl. test
thank’s, you realy help me !!! :slight_smile:
Re: some mtl. test
ey, Could you plees explant how you made the lampshade. I am a Dutch student end I hope that I can use your tecniek. If you would like to explan it.
Regards DW
www.112design.org
