Parts of the cabinets and the flooring are blurry. I am using the intel denoiser this time. The last render denoising was set to None and my wood floor was very noisy. I am going to try a render with the Corona denoiser. Any suggestions? Is there an update? Thanks
Denoisers by nature blur things, which is how they remove the noise. We’d really need to see the render to comment - the thing about noise is you should give enough passes that the noise is not extreme, before letting the denoiser “tidy up the rest”. Since you said previously it was “very noisy”, then it is possible you hadn’t let it run for enough passes. Share the image, and info like how many passes you rendered for, what the noise level was, and so on ![]()
TomG sorry I did not post a picture. I am rendering 1000 passes and it takes 3 hours and 20 minutes. I will see how it looks with the high quality corona denoiser. So far after 150 passes it looks alot better. If I have further problems I will post some pictures Thanks
