Hello
If I want to use VrayRt, for the first time I turn on my computer, before running “VRay RT render server” I need to go to windows task panel and terminate processus for :
- Vray.exe
- vrayrtspawner.exe
If not I have a “10048” error.
What can I do ?
Thanks.
(vrayrt, vray sp3, max2010, xp64)
I had the same problem until I ran “Remove V-Ray RT render server as a service” from the Chaos Group folder in the Start Menu. I may have initially made the mistake of registering it as a service, thinking it worked like the V-Ray licensing service on the local host, but I guess it doesn’t. Apparently, this V-Ray RT service registration option is only for the render slave machines and _not_ the local workstation running your active 3ds max session. If the V-Ray render engine service is already started in the Services app, you’ll get the port 10048 opening error when you use V-Ray RT in an ActiveShade window, and the scene won’t display.
I’ll try this ! Thanks :-))
