I tested using vantage 1.42
Currently, vraybitmap is supported directly within the vraydome
However, when I put vraybitmap into colorcorrection or RGB tint and associate it with vantege, vantege cannot read the nested vraybitmap
Vraydome maps vraybitmap (normal reading)
Vraydome maps colorcorrection RGB tint vraybitmap (failed)
Hi q976431,
By “cannot read the nested vraybitmap” do you mean it doesn’t load it in the environment or it does not apply the color corrections but still import it?
Alexander
It is not loaded properly in the vantage environment
Is color correction applied
Because I can’t read the nested vraybitmap now, I haven’t been able to test whether the color correction result is correct
It is not loaded into the environment
Color corrections are not supported for the HDRI environment.
Only for the physical sky, but it’s limited to a few of the “Color Correction” parameters.
This is because the physical sky is a baked texture anyway.
We have it logged to improve this and allow color corrections for the HDRI environment.
Greetings,
Vladimir Nedev
Will you consider supporting the following situations?
Vraydome-maps-(colorcorrection-vraybitmap)
Vraydome-maps-(RGB tint-vraybitmap)
Vraydome-maps-(colorcorrection-RGB tint-vraybitmap)
Even if the color correction result cannot be applied, at least the vraybitmaphdri contained in it should be read for vantage
The ColorCorrection node should already be skipped properly.
I will add skipping of RGB tint node as well.
Greetings,
Vladimir Nedev
When I tested 1.5.0, I got the correct results. Thank you very much
At present, I also found a problem
Vantage will not update automatically when I change the Vray bitmap map link in Vray dome
I guarantee that live link has been linked normally
Unfortunately, when I test vraydome, I can’t get real-time feedback on any parameters
But vraylight plan is normal
I have to cut off the real-time link and re link
The vraybitmap that has been modified to the new map will take effect
Does this need to be optimized?
Because vraydome cannot be adjusted in real time, it will lack some convenience
For example, vraydome-map-vraybitmap horiz.rotation is associated with vatage in real time for rotation adjustment
Now these vraylight planes are adjusted in real time normally, but the vraydome is invalid
Hi q976431,
The Live Link currently have these limitations and require a restart of the Live Link Session in order to be updated properly.:
- Updating of:
- V-Ray Proxy files (.vrmesh)
- Environment
- Light textures (e.g. rectangle light texture, dome light texture)
We have these in our TO DO list but cannot give ETA on them. We will let you know when there is some development and they are ready.
Alexander
Thank you very much. That’s what I want to know
Hi, I come to feedback related questions again
I have seen that the previous issues have been fixed in the 1.5 and 1.6 updates.
But there is still a related issue, because VFB2’s LightMix To Scene will nest a VrayCompTex for the outermost layer of the Vraydome map, if my Scene used this button earlier. Then the problem arises again. Could you also support VrayCompTex?
The Vraydome map after LightMix To Scene is no longer linked in real time. Hope to fix this problem
Now it has the following situation
Vraydome-maps-(VrayCompTex-colorcorrection-vraybitmap)
Vraydome-maps-(VrayCompTex-RGB tint-vraybitmap)
Vraydome-maps-(VrayCompTex-colorcorrection-RGB tint-vraybitmap)
Hi q976431,
I will log in your request and will inform you when there is some development of the matter.
Alexander
