maybe some mentalray like shaders (glare,ocean…) i was wondering why doesn’t vray have such feature.also it needs more material types like in brazil and final render (by final shaders)
yeah that would be nice… ![]()
paul.
A more intuitive SSS and maybe a dirt shader are definately on my wishlist, but at a pretty low priority as in regards to other more serious issues that need fixing before 1.5 is released.
I vote for that too, shaders and preset materials would be really nice to have, after 1.5 is out of course.
Regards,
Nenad
This has all been asked for along time ago. And I believe 1.5 will include some shaders.
i hope so
Anybody got some good tips for chrome material in vray 1.45 ?
Nicolaas
Hi Nicolaas..
have a go with this … maybe a little dark, havent had a chance to render it..
Hiya Natty,
Our private 24/24 7/7 helpdesk, thx m8..
Indeed, nice material. Did a test scene with it.
Waddayathink.
yeah maybe a little dark ![]()
whats with the IOR of .2??
Thats the frensel falloff … not refraction
.2 is closer to silver not chrome, but in the end it is what looks good. I like 10-20 for chrome.
yes I use roughly 10-20 for chrome as well.
hi guys
is it necessary to set the reflection max depth to 20?
i mean, how many reflections do you see in the chrome-globe?
does it look diffrent when set to…maybe…2?
how are the rendertimes compared to each other?
don’t have the time to test it myself, sorry.
greez
ale
yeah a depth of 20 seems high for me, I usually keep it at default. Only time youll really see a difference is when you have visible interreflections…
I always use that value due to heavy scene’s .. the reflection’s seem to work better. at the end of the day it’s just a simple material .. adjust it to your own use. ![]()
Just want to add:
You can do nearly all shaders with VrayMat + Falloffs + shellac.
But a fact Skin shader (or even an animate able) can be done.
They same goes for speed with falloffs and shellac.
So there is room to improve Vray, maybe in 10 years when Vray 1.6 comes out :lol:
regards,
robert
I agree that nearly every effect can allready be done with the features
available at present.
For my part i do not need any front end shaders like carpaint, glass or
wax because they are to much dependant on the light situation and need a
lot of work anyway.
I would like to have more faked things. Like faked translucency as offered
by the raytrace or standard material.
A selfillumination option with an additional gi multiplier like it exists for
aura.
A fast faked skinshader like the new MentalRay Skin Shader.
And a good volumetric shader would be nice as well.
I don´t know if anything changed in 1.45.
But with 1.09 it was not possible to render translucency inside a shellac material. Actually it worked with the blur “multi blender”. Would be nice
if this could work with shellac, too.
I also have some ideas for the translucency.
Instead of a simple color picker for the “fog” color I think it would make
more sense to split this up into two parameters. A color picker where
you could just select hue without the possibility to adjust saturation btw.
black/white levels. (The lighness/saturation is dependend on the thickness
of the object anyway)
And an additional spinner for brighness that might be called “density”
that has more than 255 steps. My problem is that for most shaders
my fog RGB levels look like this 255,251,247.
This means it´s nearly white in the mat. editor. But dark orange when rendering (again dependig on the object size/ thickness)
And sometimes the difference between one RGB step is just to big.
Another nice addition to the translucency would be something like a worldscale parameter. When you make a skin shader for example
and you want to use it in another scene where the objects have a different
scale your shader is very likely useless due to it will render completely different. Having a scale parameter at this point would make it a lot
easier to work with ready build shaders in different scenes.
samuel_bubat I like your ideas. It would be nice to have the options you mentioned in Vray and be able to use them in Render Elements. I hope the new Render Elements in Vray 1.5 are going to support more than just the Vray material as just Vray Material support is very limiting.
Looking forward to 1.5!!!
