First of all, many congratulations on this software, gives astonishing results with less effort > giving more access to creation and development of scenes. Thank you for creating this.
Here’s some stuff I did with both evaluation trial and official version. Hope you guys like it.
What I wish to be fixed in further to come versions, is the reflection depth, presence of an alpha channel of render export and ability to hide stuff in reflections (light sources, etc).
@diaconescu_valentinaurelian Thanks for your positive feedback, you indeed achieved good results!
Regards the alpha channel, have you tried to export with active “Material-ID and Depth Channel” which includes black color for the background which should allow you to knock out the background of it.
thanks!
yep, that’s the workaround I’m using actually
@Why should this be an workaround? Isn’t that a solution?
that’s what I’ve said, that instead of a present alpha channel I’m using the ID channel and worked pretty well.
