Something with Lightmix crashing DR2
When rendering the attached scene using DR rendering with V-Ray 7 update 2 DR2 (7.20.00 build 33207), it crashes immediately.
The problem is resolved by removing the LightMix element.
Tested with max2026 and max2024
oaktest_03.zip (78.4 KB)
We already have this logged (internal tracker ID: VMAX-15109). It’ll be fixed soon.
Ok, so it was a known issue. I’ll wait for the hotfix.
Any update on VMAX-15109?
It’s fixed in the internal builds. There will be a stable build soon enough.
Hi, I’ve found that unchecking “show map on back” (3ds Max’s bitmap and V-Ray bitmap) doesnt work properly in V-Ray DR2. Is that a known issue?
Could you clarify? What exactly doesn’t work? I tried it on a simple scene and rendered it via DR2, and everything seems in order.
We already have this issue logged (internal tracker ID: VMAX-12486). I’ll add a bump on your behalf.
