Hi guys.
Have discovered your software recently. It’s astonishing compare to the work process for an export in Unreal Engine.
Here’s my issue, I have to say that I’m really a newbie with this software, but I haven’t found the solution neither in the forum nor by myself trying to switch the options in enscape.
The fact is that when I import a sound / noise in my sketchup model, the volume is absolutely poor in enscape. I’ve tried everything I knew, wav and mp3 format, increasing the rings size of the sound, elevate it to the viewer’s height, the switch is enabled of course, at 100%, and windows volume too, loudspeaker too.
If you have any idea, that’d be great.
Thanks.
Best regards.
Hey @mangrove , thanks a lot for your kind words and welcome to our forum!
I haven’t been able to reproduce this problem quiet yet, so may I kindly ask, when playing the corresponding example sounds (which you’ll find here: C:\Users<YOUR_USERNAME>\AppData\Local\Enscape\ExampleSounds) with, windows media player for example, the volume is completely normal?
Also, in case you weren’t using our example sounds, could you maybe forward me the sound files you’ve been using? Do they also sound normal volume wise when played with windows media player?
Hi, thanks for your answer.
Unfortunately, I don’t have this folder. As shown on the attached file.
I already tried playing all the samples using WMP, VLC, and the volume is normal.
Maybe there’s a stereo space mode or something like that.
Best regards
Hi again
Finally the problem resolved by itself rebboting the PC.
Sorry.
Thanks for your support.
Closed topic
@mangrove , no worries, happy to hear the problem has resolved itself!
Let me know in case you experience any further problems, or if you have any questions.
Do you think that enscape will allow one day to put a video as texture?
This has been requested before a few times. I cannot say when or if this will be implemented soon, but we are aware of the demand for this and I’ve further up voted the corresponding topic on our agenda through your behalf as well!
Thanks for the feedback!
Without being able to promise anything yet, this is something we want to implement in any case. It may come with 2.9, but again it’s not completely certain just when yet.
