SP3 Crashes too many times.
I have been using it since it was announced and I have had too many crashes.
With SP2 VRay hardly ever crashed on mr.
I don’t know what the reason might be as it is not something that I changed that caused it.
Nir
have you tried uninstalling and reinstalling VRAY?
The crashes happen when rendering final renders with a bit higther resolutions (ever at 1000 pixels it may crash)
I rendered very big images prior to SP3 and it always did well. (4000-6000 pixels)
Maybe ur using new max, where bitmap pager always on, so it might lead you to a problem :smile:
MAX installation is very old and works laike a charm
but I will check the bitmpa issue.
although the scene is NOT bitmap oriented as I have scenes with many big bitmaps
Can you send me a scene that crashes to vlado@chaosgroup.com so that I can take a look at what may be wrong?
I will
Do you need the bitmaps as well ?
Nir
If it still crashes without the bitmaps, I don’t need them.
Best regard,
I sent you the files but as I am in a hurry - I re-installed SP2 and the scene does not crash.
NIR
Yep, I got it and I’ll be looking at it.
Hi
Can you tell me good news ?
I am still waiting for a solution to my SP3 crashes (I am using SP2 in the meanwhile)
NIR
I’m still working on it.
Thanks for the prompt reply - you are working too hard !!!
:wink:
Nir
So actually I found the reason for this. The problem has been there also in all previous versions of V-Ray, but became apparent only in SP3 for some reason. There will be an update going out next week when we also release V-Ray for 3ds Max 2010.
