SP3a DR is not rendering final images for me.
I have a scene that works fine locally. All the systems have an identical setup with latest plugin. When I try to render with SP3 the scene transfers than it just hangs - it says it’s rendering but the bars are stuck at 99%.
I’ve tried the scene over and over again to see if there is something I did wrong or differently but I keep getting the same results.
My method is to usually save out a lightmap locally, then work from file. (works fine)
Create an IRmap. (works fine - all machines participate)
Then render final from IRmap with the lightmap turned off. (loads then hangs)
I didn’t have any problems with SP2 and rendering DR.
I just tried Brute Force + LC and it works fine. It takes a while to load however. The progress window says ‘Rendering image’ at 99% on the bar then appears to sit for a couple of minutes. After waiting, it starts to render.
Running XP Pro x64 2009 on all machines.
