SP4 installer crashes on installation
I´m currently unable to install the SP4 on any of my renderfarm computers.
Running Vista 64, latest update, the SP4 installer exe cannot be started.
There is no way currently that I can install SP4. SP3a was no problem at all…
Anyone knows what might cause this problem ?
did you try to copy the installer locally?
if you have it in your network and you run it from there you could get some problems
Thanks for the quick response.
I´ve tried both and both didn´t work on the renderfarm computers.
Anyway I just found out about the new SP4a version, which installs
without any problems. So I´ll just use this version instead.
Thanks,
Martin
It will happen if the installation has not downloaded correctly too. I’ve been meaning to add a checksum that the installer verifies upon start, but haven’t gotten there yet.
