any way to make a shortcut to the “show last VFB” button in the render options ???
If you check in your “customize user interface” in the vray section, you have a macroscript for that.
thanks, was looking for that one… ![]()
The main reason why I like AO / VrayDirt as an alternative to real GI is to eliminate GI flicker. Would this enable me to use brute force for GI as a substitute for AO and save som render times? Or would brute force still be slower than AO?
Had a look at this but can’t work out how to do it???
Could you eplain a little if possible please
Cheers
