special lamp
hello all
I have to model this kind of lamp. there are many of these acryl sticks in a certain shape. the problem is to give them a curveshape when looking from the side (frontview) there is also a shape in topview.
how to model it best? with hair modifier in max I have the benefit to cut the sticks with a map, but it not only cuts the sticks, it scales them, that’s bad.
besides it has no collision detection.
maybe with vrayscatter? but I haven’t used it before.
or with forestpro, but I don’t know how to cut the sticks?
any other ideas?
thanks for help.
best regards
themaxxer
I don’t know what the plugins you report can do…but one standard solution can be to model one stick at the maximum lenght, duplicate it with a regular grid following the boundaries of the top shape.
For the different lenght you can try to use the same method of the pin animation video (if I remember it uses a displacement map to move the pins).
For cancel the sticks that are over the boundaries of the top shape you can use an opacity map.
I know it’s not a very clean method and not precise (the displacement map drives the different lenghts of the sticks ) but this is the first think I thought.
Good job
its kind of possible in vrayscatter, but it won’t map just the z scale of the sticks (you can map the overall scale). In your examples the variation in length is quite subtle, so maybe you wouldnt notice that the tubes vary in x and y scale? vrayscatter is certainly a very quick way of doing it.
see attached, 5 mins of messing about to see if it was possible!
I made a similar light a few years ago.
I used the animated pinboard method that was used in the NIN video and it worked really well. The most time consuming thing is painting the height map.
PG- I hope karba is paying you royalties for all your promoting of VRayScatter :slight_smile:
well I would use particle flow or scatter ( I prefer PF ) to distribute the cylinders on the surface on top, select bottom vertices and use noise/wave modifier to adjust the length of the cylinders…select bottom faces and view align from bottom view…
or maybe scale cylinders i Z in your particle view…
well, thanks a lot for the great ideas.
I now use the forestpro plugin to distribute the sticks on a curved shape surface.
It works great!
best reagrds
themaxxer
here’s my quick try. I first modelled a curved/wavelike surface, then used pf to position particles on it, randomly changed z scale to add variation in length, convert particles to mesh and then aligned vertices to grid.
I find pf gives much more control over these kind of things, and you can keep particles apart to avoid overlapping/intersecting cylinders.
edit: well, a bit too late it seems. glad you sorted it out :slight_smile:
wow, not too late! I will try your way. It looks exactly what I need.
thanks for your work.
best regards
themaxxer
… Rivoli!!! :slight_smile:
damn that’s nice…I wish I’d understand particle flow.
must give it another look.
cheers for that, but really, it’s definitely less complicated than it looks. the flow it’s a very basic one, just a couple of operators. but I guess it’s an effective enough method, basically I just had to model the surface on which the particles are emitted. before converting everything to mesh you can even update/change it on the fly. of course it’d be nice to have an interactive way to do it from the beginning to the end, but I couldn’t come up with anything that works.
Mind sharing the file rivoli. That looks interesting but my knowledge of pf is limited.
no problem, will do tomorrow morning when I get to the office.
here’s the file, max 2010. hope it’s useful somehow:
http://www.caribouz.com/vray/lamp\_2010.zip
Thanks for sharing!
