There is the VRayMTLReflectGlossinessBake element which bakes the Glossiness map.
Haha, do this for a city scene with 100+ assets. All Mtl. ID’s whildly spreaten over the atlas maps and say that again:)
I hope I’ll never have to do that
But so far, even with scenes with 20-30 materials, it’s a rather fast workflow. Not ideal, but manageable.
The workflow I discribed isn’t capable to bake light. Its just a way to get exactly the maps you plug in the VRay Mtl.
I know. I just mentioned that I wasn’t baking light, because you said using elements in “render To Texture” to bake Glossiness, Diffuse etc would require long lighting calculations. So I said that this wasn’t needed in my case
Yes, if your target is PC and/or PC/VR I’d highly recommend to use the Valve Lab Renderer which can be found in the Asset Store for free.
It has a Lightmap override in it’s standart material and the performance, aa and direct shadow quality is way better according to the the unity standart renderer.
But you can’t use any post effects than.
We are doing VR mostly. I’ve already asked our developer to look into the Lab Renderer, but so far he hasn’t found the time to do that yet. Now, after your post, I will push him a little!
Good advise! I didn’t know it had that lightmap override!
If your target is mobile or weaker Pc and no vr. You should use the standart renderer.
We have a script here witch overrides the lightmap array with costum lightmaps. It also can change the lightmap ID of the objects. I found it somewhere in the unity forums and a programmer here did som changes to it. I’ll post it here later, can’t get my hands on it right now.
That would be really cool! Mobile platforms and lower end PCs will surely be targets sometime in the near future. We are still in the early stages of setting up our interactive 3D department.
At the moment I’m not really shure which element to bake for lightmapping and how to edit it in PS to get a nearly identical result in Unity. I’m still testing.
Maybe a RawTotalLighting map…? That should contain the total diffuse (direct + indirect) Lighting which hasn’t been multiplied by the diffuse surface color of the materials yet. That’s what lightmaps should contain, right? . Not sure if the RawTotalLighting element contains shadows, though, but I think we could bake another element that contains the direct shadows (RawShadowMap?) and multiply these on top?
