specular map
Is ti possibile to use a specular map in SU?
Re: specular map
Shore buddy, I actually made an tutorial about applying those maps. Check my post:
Re: specular map
thank you!
Do you know how can i create a spotlight?
Re: specular map
There are no actual spotlights that you can use in SketchUp. You would instead have to model a structure that resembles a physical spotlight, and then toss a omni light in there, just like a lightbulb in a physical spotlight.
Re: specular map
That is correct. I suggest you search andeciula’s IS light tutorial. He simulated very well a spotlight, with all that you need ( opacity maps, geometry).
Re: specular map
Sorry but i can’t find it. where is it?
Re: specular map
