I have to output an image in 8000 x 8000 pixels. On some scenes the specularity (linked to the glossiness of a material) no longer reacts when I want to render beyond 2500 pixels. For some scenes it works in cpu. For others neither cpu or gpu. Is there a value to increase to have the same result in 2500 pixels or in 8000 pixels? thank you.
Resolution doesn’t matter, larger pictures should look identical without tweaking.
If you can share a simple scene showing this issue I can check if I’m able to reproduce the problem.
