Speeding up workflow AEC and such
Hello dear people,
I see lots of people who are doing architectural visualisation using vray to get the nice lightning and materials.
Therefor this should be a nice place to discuss some workflow optimization thoughts :slight_smile: as we all are proberly working against deadlines…
Well here is one thought:
Using ‘preset’ objects to speed up modelling.
AEC objects are very fast to create, but they are very limited (only a
couple of doors etc. when i for example would need to create a window
above the door i have to adjust things :slight_smile:
i dont think it’s possible to create your own objects ie building you
custom AEC objects so that is to bad…
Why i find AEC usefull is that they can be adjust using several parameters. thats very fast. using custom made models that i import and adjust to fit would takes longer then to create a eac… it i could only create custom eac..
Sooooooooo, maybe there are some ideas, thought, comments on this ??
or some1 has seen some plugins or script to cover this part?
