SpeedTree v6 to Corona - Suggestion to edit the map!
Hello to all
I have a problem in mapping the opacity to the leaves (imported as a tree. FBX into Max)
Attached you will find the object
Raf
SpeedTree-palm-to-Corona.rar (10.2 MB)
Resolved.
Export Settings in SpeedTree extension .FBX into Max (Corona)
greetings to all
great Corona and Staff
You still have some white strokes around the leaves.
maru thanks,
I noticed the white edges.
Just return home better control the setting of the map
There we read later,
greetings
Raf
hello Rawalanche
I set it to diffuse → color range RGB 50,50,50 and disappeared the white around the Leaves
Thanks for the advice
Raf
