Hi everyone!
I have an issue with VRaySphereFade effect in combination with Glass material.
First, i did a serch on chaosforum but i did not found an answer.
i have VRay 5, update 2.3
please check the attachment (a simplified structure that presents the facts of the case) corresponding with the following text:
1. VRaySphereFade effect attached to a…
2. SphereGizmo
3. The scene contains a ground plane, a window with a std glass material
4. Issue: in the final render you wont see the “empty color” and the fade from the SphereFade settings
thanks
chris
