Sphere light
sphere light appears on reflected surfaces. this image obscures reality. Can we make this light invisible? because I use this lighting to provide more daylight to the place and it is very successful.
@brkdmrcl , thanks a lot for your inquiry and welcome to our Forum! :slight_smile:
It’s currently not possible to avoid seeing the light sources in reflections but, I would also instead recommend simply increasing the exposure brightness via the Visual Settings and/or making use of the Highlights and Shadows slider in the Image tab as well. If that does not yield the results you’re looking for please let me know with another example screenshot. Thanks in advance!
That’s a needed feature. Exclude from reflection.
