Spherical HDRi Projection onto Geometry
Hi
Is it possible in Vray ? If so, how does it work ? I have tried a few approaches but nothing is working.
The HDRi is added to the environment slot so that I can see it in the viewport. But, when I add a piece of geometry to the scene - the projected hdri shows the opposite side of the hdri, the scale is also wrong.
I’m sure there is something basic that I am not doing so, any help would be great.
N
Max does that out of the box. Assuming that you mean to reproject a panorama onto geometry resembling the contents.
From the top of my head:
Select all objects, apply a UVW map modifier set to spherical. Place the gizmo where the pano-head was
Cheers,
Thorsten
That’s not working unfortunately, have to have a look at it when I have some time.
Works fine here. The only thing to keep in mind is, that you need sufficient subdivisions on your geo as UVs are a vertex channel obviously. So it’s not like a camera map projection that does not care about the geo.
Cheers,
Thorsten
Are you using a spherical image in the environment slot so that you can see the image in the viewport ?
Ok, I managed to get that working thanks Thorsten !
The only thing is, how do I align the map on the geometry to match the environment ?
Actually, I got it sort thanks for your help Thorsten !!
