Looks strange. Don’t know, if it is a bug or not tho.
3D.part1.rar (2 MB)
3D.part2.rar (51 KB)
Thanks for the report. The issue seems to stem from the overlapping sim grid and object. Strangely, it affects only this specific fire sim - cloning it or moving it up/down on the Z-axis eliminates the artifacts. Literally, clone the sim and delete the original to resolve the issue. Otherwise, I’ve logged the issue (internal bug-tracker id: PHI-6091) for developer investigation.
I’m good at finding the weird.
But here is my 3090 apparently not quite normal too, because the bugs are not confirmed on your config. Do you have 3090 cards @chaos ?
Not sure if I understood you correctly. I did reproduce the issue with another GPU model. Does the issue still occur with the said workaround?
No, I just having other issues, which are not reproducible on your side ![]()
