spinning values with default 2.0 image upscale won't refine until mouse release
Not sure this is a bug or if I’m doing something wrong. But I really liked how interactive would update as I spin the environment around. But I can only see the image update interactively while keeping the mouse pressed when the image upscaling factor is at 1.0. I need to release the mouse press on the default 2.0 to see the image update. Thanks
after more testing I think this is caused by something else. When I minimize all my other windows on multiple monitors and bring the material editor over to the main monitor, it updates interactively with the default 2.0. So it’s probably my computer setup.
Tried this:
  • Max on monitor 1
  • simple scene with a teapot
  • material editor > create corona bitmap > pick hdri > place in the Max environment slot
  • start IR docked in viewport
  • material editor on monitor 2 or monitor 1 (did not make any difference)
  • click and drag the rotate > environment spinner in the Corona Bitmap
  • observe the environment rotate in IR
Set IR upscaling factor to 1 and 2, no difference.
So I was unable to reproduce it. If you can provide more information how to reproduce it, we can investigate further.
