Spline fall off only up to a 100 cm
Am I right to understand that scatter along a spline fall off can only be set to a limited distance, in my case up to 100 cm.
Mac Studio Ultra
Most recents build of OS, C4D and CR.
Hi there,
Can you share an example here?
It’s this one, see attachment. Between near and far seems to be limited from 0 to 100cm. Is that correct.
Hi, yes, 100cm is the limit here. We will update the article accordingly.
Ok.Can’t it be much more. To scale down vegetation within 1 meter is not much.
So I have checked this and it seems that it has changed since the article was published. Please try clicking on the spline, then expand the UI using the arrow and manually input your distance.
