Split to Avoid out of Memory in Higher Resolution
Status: pending
In order to avoid the run out of memory of the GPU when render at high resolution it will be very useful to have an option to flag “split image” so the render is split in four stripe, calculated one after other and at the end atomatically resembled ad saved as one image. This basic technique is used by many renderfarm and in Vantage it will be very useful because GPU at the moment has 24Gb max and when render a Hi Res (8k and over) it is very common to run out of memory obtainig many textures errors in the images.
Submitted on AHA Ideas (VANTAGE-I-95).
Totally agree.
Urgent needed I think.
Split could be made with small gradient transparency overlap to avoid visible stiches.
Submitted on AHA Ideas by Mat Olszowy.
Great Idea
Submitted on AHA Ideas by Hashmat Vikas Builders.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
